Compression Ring for a Dome
I have a roof structure 25ft in diameter in the shape of a dome that will require a 2ft diameter compression ring.  The dome will have ribs constructed of HSS tubes and will connect to a steel compression ring fabricated out of plates.  Does any body know of any good references to look at to get a good feel for the forces that would be in the compression ring?  I have Risa 3D and Staad Pro but I would like something other than a computer to analyze the forces in the ring.
RE: Compression Ring for a Dome
Sounds like a very small Schewedler dome!
There are two ways that I have used to analyze this type of dome by hand:
Method of joints
       and
Membrane Stresses
I would second eawarfo's request for a good reference on a simple hand calculation method to get a rough idea of the forces in a compression ring.
Thanks for the responses.
Roark's Formulas for Stress and Strain includes circular rings with N uniform radial loads, which sounds like what this would be.
