heating a yoga studio
Someone mentioned using radiant heaters to heat a yoga studio to 100 + degrees. I have one that I am looking at but it has 24 ft. ceiling and no gas. Any ideas where I would locate the heaters to get the maximun temperature in the space? Since heat rises I'm not sure if that concept would work. Any thoughts?
RE: heating a yoga studio
In reality, heating purely radiant-mode is going to make people a little uncomfortable- especially if they get in each other's shade. They'll feel drafts due to free convective circulation of the air. So you need to do a little air warming as well.
Radiant energy intensity is going to fall off with L^2. So unless you want to install a plasma "solar simulator" 24' above the yogis' heads, you can't put the sources up near the ceiling and expect them to provide comfort. You need them lower, closer to the people, and more of them to cover the space.
The ideal thing to heat is the floor. It'll radiate uniformly to all the people in contact with it- and it's close, so the L^2 effect is minimized. The enlightened ones who can levitate won't mind the cold...Tubing embedded in a concrete or gypcrete slab, circulating hot water, is the usual solution. If you've only got electricty to work with, you can use sub-floor mat-type heaters that go under a (thermally conductive) finished floor surface such as tile.
100 dF would seem to me to be too hot for any one doing yoga. Of course you could also increase attendance as each human generates about 100 watts of heat. I understand that Grand Central Station in NYC is heated by people.
