parts "hiding" during section view
When working in an assembly if I create a section view, then go to edit a part in that assembly, and then go to edit a previously created feature in that part, the part I am editing will disappear during the editing of that feature. When I complete editing the part and hit the rebuild button, the part will reappear. Is there a way to keep the part being edited from hiding (disappearing) during that editing? This only seems to happen if I'm in a section view.
RE: parts "hiding" during section view
I dont know why the parts/features disappear during section view but I have found it to be hit or miss, especially with imported surfaces.
SW2008 Office Pro SP4.0
Intel Core 2 Duo CPU
2.2GHz, 2.00GB RAM
QuadroFX 3700
SpacePilot
You can do the same thing via the feature tree in the drawing. Click on the drawing view/section or whatever and select the parts you want to hide/show and select the appropriate selection in the right mouse button window.
James Spisich
Design Engineer, CSWP
