Axis in STAAD.Pro & Section Wizard
When importing user defined sections from Section Wizard, does STAAD.Pro use the same axis (Z & Y axis) system as Section Wizard or does STAAD.Pro instead use the V & U axis
of Section Wizard?
I need clarification on this because I am dealing with some unsymmetrical steel shapes where the Z & Y axis does not align exactly with the V & U axis found in Section Wizard. If you are familiar with a steel angle member and seen how STAAD.Pro rotatess these members local axis differently than a symmentrical shape like a W-shape member to the global axis you know what I am referring to.
Attached please find a section Wizard file (Free Sketch).
Thanks in advance!
of Section Wizard?
Thanks in advance!
RE: Axis in STAAD.Pro & Section Wizard
