Interpret CMM Data without Pro/CMM
Having heard that Pro/CMM is not worth purchasing, I assumed that the export functionality of PC-DMIS (CMM software) can give me enough IGES data to create a surface from a quilt feature.
Unfortunately, I have been unsuccessful so far. I have tried exporting PC-DMIS measurement data (created using SCAN feature) to both IGES and STEP formats. The closest I have been is to have an IGES file that graphically shows the CMM 'tool path', but am not able to transform this into a surface.
Does anyone have experience with this? If so, give me some suggestions for reverse engineering parts with this method.
Recneps
Recneps
RE: Interpret CMM Data without Pro/CMM
If you data is points. Try making the curves through the points and then making the surface through the curves.
ProEpro
www.whitelightdesign.com
Recneps
