A-286 STRESS-STRAIN CURVE
Can anyone out there supply me the above info, or points from which the Ramberg-Osgood equation can be formulated?
I cannot find what I need in any of the handbooks to which I have access.
Thanks in anticipation.
RE: A-286 STRESS-STRAIN CURVE
where you looking for the curves, or the points to pick from them ?  Bruhn (fig B1.12) shows the method very clearly ... draw lines at 70% and 85% E.  these intersect the stress/strain curve at f.7 and f.85 respectively.  then you normalise stress with f.7 and get ...
E*strain/f.7 = (stress/f.7) + (3/7)*(stress/f.7)^n
n = 1+ln(17/7)/ln(f.7/f.85)
Bruhn has some Ramberg data for A286 ...
ftu = 140ksi, fcy = 95ksi, E = 29E6psi, n = 15, f.7 = 93ksi
Thanks, guys. I have Bruhn and, rb1957, I have found the values you quote.
