ASME section VIII div.1 2,3
I am an new engineer. I'd lilk to know about compare between ASME section VIII div.1 2,3 Please clarification to me
Thank you for your kind cooperation.
RE: ASME section VIII div.1 2,3
Your question is toooo much "easy" for a tooo much "difficult" question..
I suggest you try to find good information in internet, books, manuals, reading ASME codes, and asking more expert engineers.
Guidebook for the Design of ASME Section VIII Pressure Vessels, Third Edition
http:
chicopee, FYI
BPVC-VIII-3 - 2007 BPVC Section VIII-Rules for Construction of Pressure Vessels Division 3-Alternative Rules High Pressure Vessels
Div 2 provides a more analytical approach and can result in cost savings due to the less conserative design.
And as RCHandy says, Div 3 is is used for high pressure vessels, where Div 1 rules are not so suitable.
Mike
Check this link which I found on the internet.
ht
page 23, 24, 25 would give you some information.
http://www.absa.ca/faq/SectionVIIIcomparison.pdf
