torque to turn bird
torque to turn bird
hi all,
I am currently looking to create a gearing system in order to turn a model bird around in circles from a 12v stepper motor.
My main problem is I am not sure how to calculate the torque neccessary, from my geared system, to turn the bird.
I have taken the centre of gravity to act through the axis of rotation and the friction to be negligable.
please advise.
laurence
please advise.
laurence
RE: torque to turn bird
TTFN
How fast do you want this thing to accelerate?
How accurately do you want to position it?
How big is it?
JHG
Cheers
Greg Locock
SIG:Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
drawoh- position and acceleration are not key with this design. I would like the bird to turn at approx. 0.5 rev/sec.
Taking the bird as a sphere, it's diameter is 350mm.
My main concern is the torque neccessary to turn the shaft coneected to the bird.
cheers
For thirty RPM you could drive it directly with a stepper motor if it can handle the starting torque, but it would require a ramped acceleration to do this, so it will need a suitable controller/driver board. As MiketheEngineer said above, friction is the thing plus a bit if experiment with something cheap and available, you'll need to support the weight as it could be too much for a small motor (grooved thrust races would be good for this).
But if you're not going to position it, do you really need a stepper motor with its need for control circuitry? There are plenty of geared DC motors about, use belts or you could even vandalise an old record player if 33 RPM is acceptable.
Trevor Clarke. (R & D) Scientific Instruments.Somerset. UK
SW2007x64 SP3.0 Pentium P4 3.6Ghz, 4Gb Ram ATI FireGL V7100 Driver: 8.323.0.0
SW2007x32 SP4.0 Pentium P4 3.6Ghz, 2Gb Ram NVIDIA Quadro FX 500 Driver: 6.14.10.7756
