Greater Internal Pressures than Discharge Pressure
I am currently analyzing some test data of a centrifugal pump. In this test the volute was tapped in four places along the developing flow path and pressure gauges were inserted. A diagram of the volute is attached. The pump was tested from 0 flow to wide-open, taking pressure readings at Suction, Discharge and at all tapped ports.
Tests results showed that at lower flows pressure develops along the flow path and is greatest at the discharge, as expected. At higher flows the results showed pressure developing from suction to the third internal port but losing pressure by the forth port & discharge. So at high flows the pump is developing a higher internal pressure than seen at the discharge.
Has anyone ever come across this issue or know of some literature that my shine some light on this phenomenon? Thanks
RE: Greater Internal Pressures than Discharge Pressure
