Galvanizing removal
Galvanizing removal
I am trying to remove the layer of galvanizing from a bolt by means of heat to acquire a sample of the galvanizing to analyze for chemical composition. Does anybody know if this is possible and what temperature is necessary to achieve this. The galvanizing should be Zn (98-99%) alloyed with Lead, Iron, Cadmium, Aluminum, Copper, and Tin.
RE: Galvanizing removal
Hydrochloric acid will also work and will probably be used in the chemical analysis, but scraping is so much easier and will make the analysis simpler.
There are some standard methods for doing this either NACE or ASTM.
With the availability of microscopic analysis techniques, you'll only need a small sliver of the galvanizing. If you could remove the bolt, it could be analyzed non-destructively using SEM/EDS.
In you case a galvanized bolt taken from a lot of bolts could have the same chemistry as one two or many or none in the lot. There is no traceability on a galvanized fastener. A keg of HDG bolts again could come from one plant or commingled with fasteners from many plants.
To overcome the standardization problem we got 2 plants to make chill bar type samples from each line at several different intervals from initial charge to a dross rake. This was when Pb was still in the mix. By doing it this way we got rid of the Fe problem from sampling by only having to remove a very small sample of Zn from any component.
After Pb was removed from the process we just used a sample of ingot zinc, both virgin and reclaimed.
h
S
Corrosion Prevention & Corrosion Control
For the test, I suggest to use mechanical method to get a sample.
