I must be smoking " "
I am trying to insert a point at the intersection of an axis and a plane. does any one have a way to do this? or am I missing somthing and its straight forward. please help
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: I must be smoking " "
The workaround is as CBL says - create a sketch and use constraints.
What does your VAR have to say about it. I would submit it as a bug.
Pierce
A sketch point and an axis, edge, line, or spline.
The sketch point is coincident to where the axis, edge, or curve pierces the sketch plane. The pierce relation is used in Sweeps with Guide Curves.
SW 2009 SP1.0
Dell Inc. Precision WorkStation 670
4096 Meg, Quadro FX 1400
Windows XP PRO SP3
Check the Help > Index for points and read both topics offered.
I used a sketch and created a tooling ball (in space) to illustrate the distances in a drawing. This method worked fine but it caused some frustration as well as cost time.
Merry Christmas
