Interferance Fit
Interferance Fit
All,
Is a steel to steel Interferance Fit going to be water proof? I am not talking about any pressure, submerged in about 6" of water.
Rich.....
Rich.....
Richard Nornhold, PE
RE: Interferance Fit
In general, the fit is not permanently (i.e. long time duration) water proof unless it is sealed.
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
If it is a moving part you could do a mechanical seal. If not I would think about a weld bead or an O-ring.
Cheers
Greg Locock
SIG:Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
Chocolates,men,coffee: are somethings liked better rich!!
(noticed in a coffee shop)
Pressfit the parts then add Loctite 409. It will wick into the small crevices and seal the joint.
Ted
Ted
If you pressurise the O ring, typically by using several atmospheres of nitrogen behind it, then it will remain watertight so long as it remains pressurised.
Cheers
Greg Locock
Your leaking o-ring must have been a very special case with motion (this case is a press fit). I design vacuum equipment and I've never "rammed" an o-ring. O-rings will seal down to their permeability in a properly designed groove with less than 14 psi across them.
Timelord
Fond as the MOD is of wasting money, I don't think this was one of the cases.
KENAT,
Have you reminded yourself of FAQ731-376: Eng-Tips.com Forum Policies recently, or taken a look at posting policies: http://eng-tips.com/market.cfm?
I was told that splashing and wave action were the hardest situation to seal, as the pressure varies locally on the seal the O ring rolls backwards and forwards imperceptibly, squeegeing water molecules through the seal. BTW this was for high end commercial sonar gear, not military.
Cheers
Greg Locock
Chris
"In this house, we obey the laws of thermodynamics." Homer Simpson
If you want to improve the sealing performance, why not put in a non-hardening self-forming gasket compound like Permatex 2.
The finish of my thought was: for a smooth cylindrical fit we can of course calculate the contact pressure. Wouldn't the joint behave similar to what you get if you cut the seam of the cylinder of contact and unreolled it into a flat bolted flange joint (with similar sealant) under the same contact pressure?
Thanks for all your input.....
Rich....
http://www.ovenind.com
