fao JohnRBaker....
fao JohnRBaker....
i've posted a thread titled UG NX4 PART VIEW but so far i've not had replies from anyone who's experienced similar problems, i believe you've replied on a similar thread to someone who wasn't aware what the icons were, is this a problem you're aware of?
RE: fao JohnRBaker....
Because this was so confusing to people, having this extra Icon and Menu item which seemed to look like what I wanted to do, made a change starting with NX 5. Basically we now have ONLY one command for adding new 'base' views to a drawing and the default behavior is to always add only views from the current drawing file which will be traditional 'Base Views'. If however you wish to add a view from another part, including the original master model part (which is supported, but which should ONLY be done if that is EXACTLY what the user wanted in the first place), the user has to explicitly select some OTHER part file from a list of available part files before he can continue. But if he just accepts the default part file selected, everything will behave the was he probably will want it to in 90% of the cases. The other 10% is when the user really does want to include the view of some OTHER PART FILE on the current drawing generally for REFERENCE PURPOSES ONLY (meaning that none of it's components will be added to the Parts List). Examples might to show the assembly where the part, being documented by the drawing, is being used. Or if there is a similar part you you wish to reference for some reason, or a very popular situation, where you have an assembly with multiple arrangements and you wish to show more than just the default arrangement, such as perhaps an assembly with some of the components in alternative positions or even with optional parts included or assembled in different ways.
As an example, look at the PDF file attached below. It shows an assembly which can be delivered with 3 different hand-wheel configurations, which were created using Arrangements in the original assembly file. However the drawing is just of the default or normal configuration, but I added two additional views, only these were created as explicitly from the original assembly, just each using a different arrangement, each showing a different style hand-wheel. So of the 3 isometric views in the lower right-hand part of the drawing, only the first one on the left was created as a normal add a 'Base View' type of operation, while the other two were added using what used to be called prior to NX 5 as the 'Add View from Part' command. Note that Parts List only reflects the content and qty of parts from the original assembly, the one shown in the orthographic and the first isometric view.
John R. Baker, P.E.
Product 'Evangelist'
NX Design
Siemens PLM Software Inc.
Cypress, CA
http://www.siemens.com/plm
thanks again for your input
dave roberts
