Creating vertices
Creating vertices
Creating vertices
I have a steel plate and i have more than 100 rivets which transfer loads to the plate. I want to model this plate. Can i create vertices (for point loads and Boundary conditions), other than Partitioning the part.
thanks inadvance.
RE: Creating vertices
I think you will have to partition the part. You may be able to do this by partitioning the surfaces instead of cells.
gurmeet
