large displacements
large displacements
hi,
does anybody know a open software to analyze beams or columns with large displacements ?
RE: large displacements
Not sure how to analyse beam-columns that way. There is a good text by Levy and Spillers on the subject but I not sure about software packages.
Any of the big general purpose FE codes will do this, but you will have to pay a lot for them. It will almost certainly be an add-on to get the large displacement codes.
Cheers
Greg Locock
SIG:Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
http://www.dhondt.de/ov_calcu.htm
Cheers
Greg Locock
I have used ADAPTIC which is house-made software in Imperial College London(google it!).
but you can access ZEUS as well:
http://mae
But apart from software, you have to be able to set up the relevant matrix for geometry of the column to derive out its buckling load factor.
hope it helps...
Sam
i found calculix, i will have a look...
i will also try adaptics, if possible
do you know how i can get ADAPTICS ?
Attached is a screenshot of the output.
