Ferric Sulphate feed line problems
We feed ferric sulphate thru a 1" pvc line to our water plant clarifiers. I've noticed that the line will get partially plugged after 3 or 4 years, to the point that the line is only half available .
We store the ferric sulphate in fibrglass tanks.
Could the precipitated out material in the pipe be coming from the tank?
If not then why does the line build up like this?
Does ferric sulphate normall precipitate out in the lines forming a
rather hard material? The ferric sulphate is fed neat.
Any suggestions??
Any suggestions??
RE: Ferric Sulphate feed line problems
Thanks. We'll give it a try.
