anyone working on the electrical shaft
is there anyone is working or have worked on the electrical shaft ,i would like to have some help.
sincerly
RE: anyone working on the electrical shaft
One using wound rotor induction motors connected in a special way, the other using VFDs with special control arrangement. Which one are you intrested in ?
i meant the electrical shaft witch use a wound rotor induction motors connecting ,the systeme thet connect two or more motors to get them work with synchronization .
with regards
i continue to ask if anyone work on the electrical shaft the system that connect more than motors(wound rotor ind.motors) to get them sychronised .hope for your help.
with regards
