Gasket internal pressure simulation
Hi all,
I have a problem when simulating a rubber gasket between two pipes. I perform the simulation up to the final assembly process (see attached file), but I don't know how to proceede to simulate the fluid internal pressure. Is there any way to simulate the internal pressure?, any function to specificy the node pressure versus contact status?, should I change the model?.
If you have any tip I would apprecitte.
Thanks.
David
Thanks.
David
RE: Gasket internal pressure simulation
I found a solution for this problem that works fine. Perhaps could be usefull for someone else.
The solution is to use the user-function pr-leak.f or pr-leak2.f. These functions allow to define a pressure boundary condition that will apply only in the faces of the element are not in contact. Perfect to simulate gaskets under pressure.
Bye
