Drawing practice
Drawing practice
Drawing practice
I have a round machined part which has 2 features that were drawn 90° apart but had no relationship or tolerance noted. One was a milled flat and the other a drilled hole. We have made many similar parts over the years and always assumed there was no relationship since none was noted and never had a problem. On this part however our customer has rejected parts because we did not hold the 90° as drawn. My question is "is there a standard which clarifies this situation"?
RE: Drawing practice
Yes, there is.
ASME Y14.5M-1994 1.4 Fundamental Rules
(i) A 90deg angle applies where ... lines depicting features are shown on a drawing at right angles and no angle is specified.
This assumes that ASME Y14.5M was specified on the drawing.
Patrick, are you actually working to ISO standards, as this is the Iso forum.
I can't remember if it has equivalent wording to the ASME spec in one of it's many documents.
In ASME the assumed 90° invokes whatever the general angular tolerance is, or if applicable (such as on the outline of a square part) the general size tolerance.
KENAT,
Have you reminded yourself of FAQ731-376: Eng-Tips.com Forum Policies recently, or taken a look at posting policies: http://eng-tips.com/market.cfm?
