WTP dehumidification
Hi
I'm designing a ventilation system on a water treatment plant. We're not using dehumidifier or AHU, we're only using fan for basic ventilation. There is going to be open water tank inside, and the latent load is going to be high.
The ambient condition: DB=68F, WB=60F
I'm trying to use the Psy chart to find the answer, but the explaination regarding this scenario is very limited, so I couldn't find the answer on my on even thought I've spent days researching on it. Is it possible to use fan only and exhaust away the moisture so that there's little or no condensation? If so, how do u do the calculation?
Thanks.
Thanks.
RE: WTP dehumidification
http://www
Once you have that, it's a straight-forward psychrometric exercise.
Evap Rate = 0.1 * Area * (Vw - Vp)
Vw is the vapour pressure of the water, which is dependant on the water temperature.
Vp is the vapour pressure (vapor pressure in the US I guess) of the air, which is dependant on air temp and RH.
Once you have your evaporation rate you can determine what the change in humidity would be given your air.
The next step would be to determine the maximum desired RH within the space (say 60%) and then you would calculate the required outdoor air rate (at design wetbulb conditions) to dehum the space to your desired maximum.
The main issue I imagine is that, in conditions of high outdoor wetbulb you will little to no ability to dehumidify. If that is a concern, you'll have to look at some form of mechanical cooling, or dessicant dehumidication.
