Effect of initial oil temperature on impact toughness of steel
Can any one can give me some informations about the effect of the oil initial temperature on impact toughness of steel :
IE: what happen if we quench at various temperatures: 20°C, 30 °C 40°C what is the effect on the impact toughness ?
thanks
RE: Effect of initial oil temperature on impact toughness of steel
It can be difficult to draw an exact correlation to quench oil temperature, but in general, for the best impact results, you want to have the most effective quench.  You should consult your quench oil supplier to find the optimum temperature for the oil you are using.
With that said, most petroleum oils will be most effective around 50 to 60 C (120-140 F).  At lower temperatures, the viscosity goes up, reducing the flow characteristics and the severity of the quench.  At higher temperatures, you run into problems with the oil breaking down and even problems with fire if the oil should exceed the burn point of the oil.  Again, the supplier of the quench oil will know what the optimum temperatures are, although the volume of your quench tank, size of the quenching load, and effectiveness of the heat exchanger will all be important variables.
With water or water-based synthetic quench solutions, the optimum temperature is much lower.  Again, there are really too many factors to just say any specific temperature.
Finally, you may find differences in the chemistry of different lots of steel to have a greater effect than the quenchant temperature.  There are many different variables, and quench oil temperature is only one
rp
Great informations !
Thanks a lot Redpicker !
You always need to check the material data sheets as some materials actually require the quench media to be above RT by varying degrees.
