Suspended Building Substation
I 'm preparing design drawings for a project where the building is suspended on three cores and started at level +60m from finished floor and continue too level 120m.
Does anyone have any approach for the power supply/ substation to this building, i mean location ...how to solve the problem of voltage drop....etc.
Elecme
RE: Suspended Building Substation
Also are there any restrictions on the installations of the generator on top of the building (at 120m from finished floor level).
Elecme
As far as the gen. set goes, you may have some containment issues, eg you wouldn't want fuel leaking possibly destroying a roofing membrane.  Check w/ you local authority.
