Linking error in Visual studio 2003
I am a newbie to UGOPEN.  I just installed Visual studio 2003 on my machine.  I configured it for UGopen by:
1. Copying the files vcprojects and vcwizard files to the Visual studio.
When I create a new project, I get the wizard from which I choose the dll or exe then c or c++, entry points etc.  Then the project is created successfully.  But when i build the project it is failing saying
Linking...
   Creating library Debug/qq1.lib and object Debug/qq1.exp
qq1.obj : error LNK2019: unresolved external symbol __imp__UF_terminate referenced in function _ufusr
qq1.obj : error LNK2019: unresolved external symbol __imp__UF_initialize referenced in function _ufusr
qq1.obj : error LNK2019: unresolved external symbol __imp__UF_UI_write_listing_window referenced in function _report_error
qq1.obj : error LNK2019: unresolved external symbol __imp__UF_UI_open_listing_window referenced in function _report_error
qq1.obj : error LNK2019: unresolved external symbol __imp__UF_print_syslog referenced in function _report_error
qq1.obj : error LNK2019: unresolved external symbol __imp__UF_get_fail_message referenced in function _report_error
Debug/qq1.dll : fatal error LNK1120: 6 unresolved externals
Any idea what is the missing configuration.
RE: Linking error in Visual studio 2003
You need to set the environment variable
UGII_USERFCN=%UGII_BASE_DIR%\ugopen
then try to build the project.
