Configuration specific material in drawings
Hello All,
I have a part with 2 configurations which are set with specific materials.  When im creating a drawing I cant get the material to be configuration specific.  The material changes to the last active configuration.  Is there any way to make it configuration specific?
Cheers
RE: Configuration specific material in drawings
Yes, and all the views are set to the same configuration.
It works for me, but I have to hit the Rebuild button? Or select the view and Ctrl Q.
cheers
That only works when you have the same configuration active in the model  and drawing.  But when in the other configuration in the part,  hit ctrl Q it changes to the other material.  This shouldn't happen.
By the way im using SW09 SP01
Nope ... I can change config in any drawing view no matter which config is active in the model.
cheers
I had the solid solutions guy have a look at it and he couldnt figure out why this was happening.
