Primary unit is fraction, how to control when override to decimal?
In a drawing, I've setted my primary dimension as fraction. For some dimensions I overrided them to decimal but I don't know from there how to control the number of digits as default. In unit you have the option to set the fraction denominator or the decimal numbers, not both.
I went to option-document-dimension-precision with no success as well. I can just override it at the dimension tab ("other", but cannot find where is the document setting for decimal format when fraction is the default)
RE: Primary unit is fraction, how to control when override to decimal?
Jeff Mirisola, CSWP, Certified DriveWorks AE
http://designsmarter.typepad.com/jeffs_blog
Follow me on Twitter
Eric
If I read correctly, you're mixing fractions and decimals together on drawings?
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 08
ctopher's home (updated Aug 5, 2008)
ctopher's blog
SolidWorks Legion
Yes, the whole drawing is in fraction but some holes and positionning are critical and I nedd to put x.xxx value but the default (when overridden) is set to x.xx and I am wondering how to change it to x.xxx. MOreover that when you override it you can adjust the number of digits to (document!)
To answer your question, I think double-click on the dim and manually change it?
You may email me.
Chris
AutoCAD 08
ctopher's blog
SolidWorks Legion
Why? Because some standard says to do so? Whadda they know?
Seriously though, fractions have been used as a means of indicating tolerance for a long time.
Tolerance (Unless Specified)
.XXX = ± .005"
.XX = ± .010"
.X = ± .020"
Fractions = ± 1/32"
Bouing,
Check your company stds, I 'think' this is not allowed.
Chris
AutoCAD 08
ctopher's blog
SolidWorks Legion
See 10.2.2.2, pg 89:
h
I have had too many arguments with machinists that round the fractions vs decimals differently.
Chris
AutoCAD 08
ctopher's blog
SolidWorks Legion
