AutoCAD 14 units
AutoCAD 14 units
AutoCAD 14 units
Why is it that when I start a new drawing, having selected "metric" then create a dimension, then modify the properties of the units it still says feet and inches??
RE: AutoCAD 14 units
It has been a while since I have had to use metric settings on AutoCad.  But if I recall, you need to change metric to a default setting in your setup menu.
Live Aloha
Frank M.
Tradewind Resources
http://twrusa.tripod.com
