GE Gear Reducer
GE Gear Reducer
GE Gear Reducer
  I'm not sure if this is the place to be posting this but I'm running out of options.
  I have a GE mod.# 7NB269JD6BA01 gear box in need of repair & no info on it. All that I've been able to turn up so far is GE sold the business, it's obsolete & no parts are available. All I really need are drawings. The castings are in good shape so it's just bearings & seals which should be available. I can't get at all of the bearings without removing gears & I'm not sure if I'm dealing with left hand threads or thread locker but nothing is comming loose. I'd just like to see what I'm dealing with before putting a torch to it.
  Anybody have any idea where I can find drawings?
  Thanks in advance.
RE: GE Gear Reducer
Thanks. Eastern PA. If I'm lucky they can fax or email. I'll give them a call.
RE: GE Gear Reducer
Call your local various power transmission distributors of gearmotor manufacturers.  They are always getting requests to provide a "drop in cross refernced" unit for something that's out of date.  Some companies will give you the unit properly sized for torque etc, and a drawing of an adapter plate you can have fab'ed up to make it fit.
TygerDawg
Blue Technik LLC
Virtuoso Robotics Engineering
www.bluetechnik.com
