Effect of Atmospheric Pressure on Pump Lift
I am sizing a small jet pump to lift a low flowrate of water into a building for a temperature measurement.
The problem is that a high amount of lift is required.
I have a pump selected that has a good amount of lift but the disclaimer says the capacities are given at near sea-level conditions.
The location is at 481 m above sea level and I am wondering what impact this elevation difference will have on the suction lift?
Thanks!
Thanks!
RE: Effect of Atmospheric Pressure on Pump Lift
Katmar Software
Engineering & Risk Analysis Software
http://katmarsoftware.com
I tend to throw in my 2 cents worth (and I have a handful of pennies).
How accurate does the reading have to be? Would pumping a low flowrate stream into a building affect the reading to a degree that you'd consider significant?
Have you considered putting the thermometer/thermocouple/RTD into the bulk of the stream?
"The problem is that a high amount of lift is required" --is this suction "lift" or are you referring to discharge head?
At 481m ASL the effective maximum suction "lift" achievable from any pumping system will reduce by something like 0.7m.
Is there something wrong with jet pumps?
Where did you get 0.7m from?
Absolutely nothing wrong with jet pumps in the right application - however, as your application is not fully explained would you be better served with a standard pump?
Where is the eductor(jet)located in your pump system - at the pump inlet or external to the pump (at the inlet to the suction pipework)?
