Wood studs composite with sheathing?
I have been asked to review an existing wood-framed building. My client wants to look at the wall studs as composite with the exterior OSB sheathing. I have never analyzed a wood-framed wall in this way and have a few concerns. One is the shear stress transfer to ensure composite action. Another is a thin-flanged beam taking axial load in combination with bending compression.
Does anyone know of an established design procedure for this?
RE: Wood studs composite with sheathing?
About all that can be said is the sheathing reduces deflection.
DaveAtkins
DaveAtkins
I had to apply a reduction factor for the plywood based on the ply construction. I wonder how this would apply to OSB with the random grain orientation?
Mike McCann
MMC Engineering
