Advice on which Pressure Vessel Book to choose
I recently became head of department for mechanical engineering, and we are branching out into designing and manufacturing of pressure vessels.
I am currently the only person with some PV experience, and I want to purchase some books for the other engineers to use. Please give your recommendations on the following books, and rank them if you could:
1. Practical Guide to Pressure Vessel Manufacturing - Sunil Pullarcot.
2. Pressure Vessel Design - Donatello Annaratone
3. Pressure Vessel Design Manual, Third Edition - Dennis R. Moss
4. Pressure Vessel Handbook, 14th Edition - Eugene Megyesy
5. Pressure Vessels: Design and Practice - Somnath Chattopadhyay
6. Guidebook for the Design of ASME, Section VIII: Pressure Vessels, Third Edition - James R. Farr
7. Pressure Vessel Design: The Direct Route - Josef L. Zeman
Feel free to recommend any other books that you may feel is better than those listed here.
RE: Advice on which Pressure Vessel Book to choose
All listed have value, you might consider adding:
Pressure Vessel Design Handbook - Henry H. Bednar
But how relevant is Bednar, since it was last revised in 1991?
IN ADDITION TO TEH ABOVE:
TEMA 9 EDITION
YOU SHALL / MUST HAVE THE FOLLOWING:
WWW.PIP.ORG
ASME Code Section VIII, Div. 1 & 2 (Vessel/S&T Heat Exchangers)
Bins & Silos
Fiberglass
Hairpin Heat Exchangers
Lined Vessels and Tanks
Low Pressure
Small Vessel & Heat Exchangers
Shell & Tube Heat Exchangers
Tanks
Piping Material Specifications & Practices
(Note - Abstracts are not available for Piping Material Specifications)
Piping Material Line Class Specifications
Aluminum Alloys (Future)
Brass, Bronze, Copper and Copper Alloys (Future)
Carbon and Low-Alloy Steels
Iron, Ductile, Malleable, or Case (Future)
Fiberglass Reinforced Plastics (FRPs) and Resins
Non-Metals/Non-Plastics (Future)
Lined or Internally Coated Steel/Iron/etc.
Miscellaneous Metals, not covered elsewhere
Nickel & Nickel Alloys
Plastics (other than FRPs)
Stainless (High-Alloy) Steels
Titanium & Titanium Alloys (Future)
Piping Procurement
Purchasing Requirements for Gaskets - PNSM0105
Purchasing Requirements for Pipe - PNSM0115
Purchasing Requirements for Fittings - PNSM0116
Purchasing Requirements for Flanges - PNSM0117
Purchasing Requirements for Bolting - PNSM0120
Use of Piping Practices
Abbreviated Piping Terms and Acronyms - PNC00002
Piping Materials Line Class Index - PNCM0002
Piping Line Class Designator System - PNCM0001
Back to top
Valve Descriptions & Practices
Valve Descriptions
Bronze & Iron
Carbon Steel
Low & Intermediate Steel
Plastic & Plastic Lined
Stainless Steel
Valve Purchase Specification - PNSM0110
Valve Commodity Code System - PNSMV002
Back to top
Piping Engineering & Complementary Practices
Engineering
Fabrication, Installation, Testing, & Examination
Procurement
Back to top
Pipe Supports Details
Anchor Bolts
Abstract
STE05121 - Anchor Bolt Design Guide
Date: 01-03 | 10-06 (Technical Correction) | 10-03 (Technical Correction)
Abstract
STF05121 - Fabrication and Installation of Anchor Bolts
Date: 08-03 | 10-06 (Technical Correction)
Steel
Abstract
STS05120 - Fabrication of Structural and Miscellaneous Steel Specification
Date: 01-99 (Complete Revision) | 02-02 (Technical Correction)
Abstract
STS05130 - Erection of Structural and Miscellaneous Steel Specification
Date: 12-98 (Complete Revision) | 02-02 (Technical Correction)
Abstract
STF05501 - Fixed Ladders and Cages Details
Date: 12-99 (Complete Revision) | 02-02 (Technical Correction)
Abstract
STF05511 - Fixed Industrial Stairs
Date: 04-02
Abstract
STF05520 - Pipe Railing for Walking and Working Surface Details
Date: 12-98
Abstract
STF05521 - Details for Angle Railings for Walking and Working Surfaces
Date: 10-03 (Complete Revision) | 06-04 (Technical Correction)
Abstract
STE05530 - Grating Design Guide
Date: 10-07
Abstract
STF05530 - Grating Fabrication Details
Abstract
STE05535 - Vessel Circular Platform Detail Guidelines
Abstract
STF05535 - Vessel Circular Platform Details
L S THILL
Bednar and Megyesy are definitely top notch texts.  Moss is just okay to me.
Joe Tank
Cobus...
I would add the classic John Harvey book on Pressure Vessel Theory to your list.
http://www.amazon.com/Theory-Design-Pressure-Vessels-Harvey/dp/0442232489.
Also, I believe that you should consider the expansion of the curricula to the "near pressure vessels" known as low pressure tanks (API-650,620)and TEMA heat exchangers.
There are also many ASME journals and research articles about pressure vessel theory and design.
Please tell us about the curricula that you envision.
-MJC
