Embedded 480V drives
Does anyone know of someone making embedded or really "embeddable" chassis drives for small (1/2HP) 460V motors? I know of several who do that for 230V drives, but I have not seen it for 480V, at least not yet. I'm looking for an embeddable version because there is a lot of uncommon communications and control interfacing that needs to be added along with specialized packaging, so a NEMA 1 (IP20) enclosed drive is going to be a waste and likely too expensive for this project.
"If I had eight hours to chop down a tree, I'd spend six sharpening my axe." -- Abraham Lincoln
For the best use of Eng-Tips, please click here -> FAQ731-376: Eng-Tips.com Forum Policies
RE: Embedded 480V drives
htt
What's the volume?
We have a low power drives division that makes customised drives to whatever spec you put forward, but the volume needs to be there..>35-40k pieces
controlsdude,
Thanks, but no, I don't mean embedded with the motor, I mean a "board level" drive that can be embedded in a larger control system that has to squeeze into a small box. Still, thanks to both of you for bringing up Danfoss' capability, I was unaware that they were doing that at any level.
Scroll to the second page.
h
Keith Cress
I think that bump on Alex's forehead might get slightly bigger with that task...
I can look into what we could do and contact you offline if you wish. Is it only comms input and no I/O? (What protocol are you looking at?)
Patrick
