Take a nozzel for PT and PG from taken nozzel from vessel for LT
Dear All,
would you please kindly tell me is it pcactical to have nozzel for PT and PG form vessel nozzel according attached file, please tell me the refered standard.
RE: Take a nozzel for PT and PG from taken nozzel from vessel for LT
2. The closest you will con=me to a "Standard" would be ISA (Instrument Society of America)
3. It is not normal to Group or Gang multiple function usage from one connection.
4. You will normally see dedicated connections for each instrument
If your question is whether it is acceptable to use single tapping for PG/PTs, the answer is yes. However I haven't seen PG/PT tapping from level gauges (this does not mean it is incorrect!).
