civil 3D profiles
civil 3D profiles
quick question on civil 3D profiles; i need to trim the existing and the proposed profile lines to the two points (at the beginning and end) where they intersect. but looks like civil 3D has them as 'embedded' objects, which i cannot even break or cut. the only thing i can do is change layer settings. also, any ideas how i can do the profile plot ONLY between those two points?
RE: civil 3D profiles
