Mirror Solid Body in Multi-body part?
SW08 Sp5.0
I can't find anything in Help about patterning an unmerged body in a multi-body model. I get the error note: Only merging features may be patterned. If appropriate, make a pattern of bodies instead. Any suggestions?
We are forced to create multi-bodies of o-rings in our models (revolved ellipse) to show the installed o-rings, and I thought it would be easier to pattern them instead of making multiple solid bodies. I could be wrong.
RE: Mirror Solid Body in Multi-body part?
In your attempt to create the pattern, did you select the feature that created the o-ring or the solid body? There are separate sections in the pattern input for features and bodies.
