phosphate dosing in LP steam generators
we have 3 LP steam generators (2 in line, 1 standby). there is one phosphate dosing pump. we were doing batch wise dosing in two generators (4 hours in each). Due to batchwise addition, phosphate concentrtion and pH in CBD was fluctuating. we desided to make it continuous dosing. but we are getting different concentration of phosphate and pH value in CBD samples of two generators. this may be slight difference of pressures of two generators. what should be the solution? putting a ristriction orifice in dosing line of generator which is having high phosphate level, throttling the valve? having dedicated pumps? if we changeover the steam generators then...? any permanent solution.please give ur views.
RE: phosphate dosing in LP steam generators
Amarjeet Singh
Reliance Industries Limited
Amarjeet Singh
In each case you could check with a chemical treatment supplier. They are experts in their field (although they may try to sell you their products
rgs
