Right-click, hold and drag. Popup menu. Can you change it?
Hi there,
You know the context sensitive, "right click and drag" pop up feature?
First of all, I love this tool. It's really nice.
I would love it more if I could change the functions and customize it...
Can this be changed?
JAY
NX 5
RE: Right-click, hold and drag. Popup menu. Can you change it?
Maybe try going onto HELP (pull-down) > DOCUMENTATION (click on magnifying glass) > "ACCELERATORS"
to see if that helps you.
The only MB3 pop-up menu that can be changed is that which is the View Pop-Up menu which gives you the various graphics and display options.  The so-called object specific pop-ups, such as when selecting a body or a feature, are generated on-the-fly by the NX software and therefore there is NO menufile which can be edited, as is the case with the View pop-up menu (as I mentioned above).
So NO, you can NOT edit the content of object specific pop-up menus.
John R. Baker, P.E.
Product 'Evangelist'
NX Design
Siemens PLM Software Inc.
Cypress, CA
http://www.siemens.com/plm
