nx3 on xp64
nx3 on xp64
my company has recently just upgraded a few of the computers to xp64 and we were using xp professional before hand with nx3 with out any problems however since upgrading windows the following error occurs whenever i start nx 3
graphics window has detected an error and is not able to initialize
general fault exception
is there any way to get nx3 to work on xp64?
RE: nx3 on xp64
John R. Baker, P.E.
Product 'Evangelist'
NX Design
Siemens PLM Software Inc.
Cypress, CA
http://www.siemens.com/plm
RE: nx3 on xp64
Cheers
Hudson
RE: nx3 on xp64
the computers have
nvidia quadro fx 540 and
nvidia quadro fx350
i know that they are compatible as i have looked on the certification page but when i downloaded the driver from nvidia for the fx 540 it only works on xp 32 not on xp64 even though it states xp 64
RE: nx3 on xp64
RE: nx3 on xp64
RE: nx3 on xp64
I´m using FX1400 with driver 6.14.11.6939 build on Feb 1 2008. Graphics is not a problem.
Quadro Release 178 WHQL
Version: 178.46
Release Date: November 11, 2008
Operating System: Windows XP 64-bit
Language: U.S. English
File Size: 49.4 MB
RE: nx3 on xp64
Otherwise the question becomes how can one install for NX-5 or higher to run under 64Bit and NX-3/4 to run under 32Bit using the same graphics card at the same time?
Cheers
Hudson
RE: nx3 on xp64
thanks for the sujestions so far any more would be appriaceated
RE: nx3 on xp64
Following are the steps to succeed in installing 32 Bit NX3 in XP 64-Bit OS
1. Install base version NX3.0
2. Download maintenance release "nx-3.0.1.3", "nx-3.0.2.3" upto which you want and copy to local directory of the machine
3. Go to start->programs->NX 3.0->NX tools->command promt
4. set UGII_BASE_DIR=C:\PROGRA~2\UGS\NX3~1.0\ and UGII_BASE_DIR=C:\PROGRA~2\UGS\NX3~1.0\UGII\
FOR MAINTENANCE RELEASE
5. Change the current directory path to the copied location of the update ..\nx-3.0.1.3 and run the batch file "ugs_update.bat" in this format
..\..\nx-3.0.1.3\..>ugs_update.bat /v
6. Change the current directory path to the copied location of the update ..\nx-3.0.2.3 and run the batch file "ugs_update.bat" in this format
..\..\nx-3.0.2.3\..>ugs_update.bat /v
OPTIONAL IF YOU WANT
7. Change the current directory path to the copied location of the update ..\nx-3.0.2.3 and run the batch file "ugs_update.bat" in this format
..\..\nx-3.0.4.2\..>ugs_update.bat /v
8. Change the current directory path to the copied location of the update ..\nx-3.0.2.3 and run the batch file "ugs_update.bat" in this format
..\..\nx-3.0.5.3\..>ugs_update.bat /v
FOR UPDATES
5. Change the current directory path to the copied location of the update ..\nx-3.0.2.3 and run the batch file "ugs_update.bat" in this format
TESTING INSTALLATION SUCCESS
7. Now go to start->programs->NX3.0->license options
8. Pick the license UGXXXX from left side and load it to right side using the arrow keys ">>" and say Ok
9. Now launch NX 3.0 and have a coffee
RE: nx3 on xp64
Any luck getting the machine to support NX-5 at the same time?
And I thought that all the updates were cumulative so why run in 3.0.1.3 and then 3.0.2.3 one after the other? Theoretically one might as easily download the latest say 3.0.5.3 and run that in. I would willingly follow your advice granted that it works, and am not doubting you rather I just wished to put the query out there because my understanding was otherwise.
That you made no mention of Graphics Drivers is puzzling since for the most part they were reportedly the main problem.
Cheers
Hudson
RE: nx3 on xp64
well i got it to work using the latest update 3.0.5.3
i don't know why that worked since the error message did say something about graphics card.
i got rid of nx5 on the first machine i tried. now i have to try and install nx3 on a computer with nx5 already installed. i will see if i can get it to work.
