Drawing Ellipse
Drawing Ellipse
Is it possible to draw an ellipse in FEMPRO. I am trying to do an analysis on a horizontal atmospheric pressure vessel with semi-elliptical heads. It is quite long and I am concerned about the saddles, but I dont want to use ASME calculations, because I want to try to make the vessel as cheap as possible. I am running into issues however when try to model the heads. If anyone knows how to do this, if would be a great help.
RE: Drawing Ellipse
1) Use a series of arcs to model one quadrant and then mirror to get the other three.
2) Draw it with a spline
3) Draw a rectangle and fillet the corners so that the ends are rounded. Divide the filleted corners into two or three segments. Use a spline and start at the junction between the two end fillets, then select one of the nodes that you created with the division of the fillet, then go to a point above the middle of the rectangle. Continue selecting symmetric points around your former rectangle. Make sure "interpolate" is unchecked.
As I mentioned, none of these are easy to get an accurate ellipse, but they will work. It is MUCH easier to develop it in a CAD package and then import. Just select the top surface for meshing and deselect everything else. Once you have meshed the elliptical surface, you can merge it with your other model. The trick to that is to make sure you are using an absolute mesh size instead of a percentage. If you go this route, you may want to mesh the head first. Then, you can mirror it to the other side and copy: join the edge to form the body. Be aware of where your saddles need to be so that you have sufficient mesh density in their area.
Hope this helps.
Garland E. Borowski, PE
Engineering Manager
Star Aviation
RE: Drawing Ellipse
I have not done much importing besides solid models from ALIBRE. Can I select a surface imported from that programt to mesh like you suggested?
RE: Drawing Ellipse
Then, "Point Select" the surfaces that make up the elliptical head. Right click again and re-select the "Select Surface for Meshing". Clearly, when you box select everything, you could hold the control key down, switch to a point select and deselect these so that they are not impacted by the original operation, but in the end, you just want the outer surfaces that make up the elliptical head to mesh.
Now you can mesh just the surfaces that are expected to do so. When you expand the surfaces in the tree, there is an indication as to which ones are selected for meshing, and I believe you can select and deselect them from the tree as well.
An alteranative is to build the elliptical head, but don't "hollow it out". This will give you probably 3 surfaces: the head in two surfaces and the interior face as one...the interior face my be two. Go ahead and mesh. Then, select the surface representing the interior face, right click and go to the bottom for "select subentities", choose lines and then hit delete. You may have to check to make sure that the remaining surfaces are complete and you may have to add some lines along the edge to close out the elements, but this way may be a little faster.
