acoustic resonance in heat exchanger
hey everybody, what can i do to solve acoustic resonance problems in a designed and built heat exchanger?.
thank you very much
RE: acoustic resonance in heat exchanger
For starters, you can check what is the cause of resonance, most likely is something you can change, like inlet/outlet velocity. You could consider inlet nozzle inserts / difusers, depending also on the current roVsq. If the bundle is removable, perhaps some additional tube support may be considered. If nothing else helps, scrap the exchanger and start all over again, minus the resonance.
Cheers,
gr2vessels
gr2vessels and christine74
thanks for the replies, I'll try to solve my problem with your advices and I'll tell you.
