Load on a Sea Water Stainer
I need to calculate the force exerted on a mesh for a sea water strainer.  flow 15,000 kg/hr 7m x 3.2m flow area. 17 x 17 mm 2mm wire mesh.  How can I calculate a force when clean and an estimate when blocked with fish!?
Any pointers would be much appreciated.
thanks,
pav
RE: Load on a Sea Water Stainer
right i've had my first thought.. if i just assume it is completely blocked, like a dam and just calc the hydrostatic head 7m deep that should be the worst case loading? is this correct?
will your pump be exerting suction on the strainer at the same time?
ye good point. I guess so, but have no info on the pump presently.  Im also guessing it will have some sort of cut off too if the strainer becomes blocked?
well, the breaker probably would kick off if it overheats, or you could add a pressure sensor switch at the strainer.
Conventional wisdom would suggest a differential pressure switch at the strainer to shut down the pump, NOT set for completely blocked flow.  It would also suggest that you build fish screens at the intake; not catch them with the strainer!
"Pumping systems account for nearly 20% of the world's energy used by electric motors and 25% to 50% of the total electrical energy usage in certain industrial facilities." - DOE statistic  (Note: Make that 99.99% for pipeline companies) http://virtualpipeline.spaces.live.com/
Presumedly this is for a power plant or something and you're not fishing with this set up.
ye fair enough.. my wisdom isnt always conventional! anyway, I'm trying to work out the max load, would a partially blocked flow have a greater load due to the increased drag or shall i just use the hydrostatic head when fully blocked?
A bunch of fish packed sideways might have a 1.4 drag factor, but I sure wouldn't want to prove that.
