Export text to pdf w/o ms office installed
I have a requirement where I need to retrieve data from a database and write the data to pdf files.The constraint is that the user doesn't have MS office installed on its machine.
I have realised that, to do so,I will have to first convert the text file to post script and then post script to PDF.
Is any one aware of any free tool to convert text to pdf?
or any tool to convert text to post script?
Tushar
Tushar
RE: Export text to pdf w/o ms office installed
If you google "pdf printer driver" or similar terms you will find dozens of options some of which are even free. I have had good success with PDF995, which has a free option as long as you don't mind a nag screen but the registered version is only ~$20.
Thanks so much for your help.
I have used the following code which did the trick:
http://www
This post can be considered as closed.
Tushar
Look into http://www.cutepdf.com/
Bradley
SolidWorks Pro 2009 x64, SP1.0
PDMWorks Workgroup, SolidWorks BOM,
HP xw8600,
64-bit Windows Vista Business
Service Pack 1
Intel Xeon CPU, 3.00 GHz, 16 GB RAM, Virtual memory 166682 MB,
nVidia Quadro FX 4600 Driver 7.15.11.6956
http://
"Pumping systems account for nearly 20% of the world's energy used by electric motors and 25% to 50% of the total electrical energy usage in certain industrial facilities." - DOE statistic (Note: Make that 99.99% for pipeline companies) http://virtualpipeline.spaces.live.com/
