Substation Fault Calculation
Please help me to find some references about substation falut calculation. 34.5kV Ring Bus (9 bus) with 3 Transformer, 60 mva of each. Thanks a lot
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Substation Fault Calculation
Ex. 1500 3phase pad, 480Y/277, with 5.75% IMP.
(((((1500*1000)/3)/480)*1.732)*100)/5.75=31377 Fault Current
Hope this helps
Trent
1. Impedances of the three transformers.
2. Equivalent short circuit impedance of the system connected to the primary of the transformers.
3. Impedance of any series reactors (if any).
4. Are the three transformers operated in parallel on the secondary side?
www.eazypower.com.
Thanks again.
