NX files on various OS's (xp 64 & 32, linux 64)
This is probably a dumb question, but are there ANY issues in using a given NX file on several different operating systems (such as xp 64 & 32, linux 64). In other words, will anything out-of-the-ordinary occur if the same file were operated upon, then saved on the one of the above OS's, and then opened on any of the other OS's?
RE: NX files on various OS's (xp 64 & 32, linux 64)
Note that UG/NX has always stored Part files in such a manner that they can be opened by UG/NX running on any OS, and this goes back to the days of proprietary systems. In fact once back in 1985 I did a demo where I started on a Data General system running AOS-VS, saved my work in mid-demo. Moved over to a station hooked up to a Digital Equipment VAX running VMS and retrieved my file and finished it up. Then just to prove the point I moved to a 3rd station attached to an IBM 4300 series mainframe running VM/CMS, pulled up my finished model, made a few changes, saved it and then went back to the Data General and open the part to finish-up the round-trip. All of this was in the span of a couple of hours, but one of the primary criteria for the prospect that we were doing the demo for was that they had to know that whatever vendor they decided to do business with would not be locked into a single hardware platform. Needless to say, that little 'exhibition' was all that was needed to settle that issue once and for all. And we continue to this day to develop our products so that the data is completely independent of the OS or the hardware configuration (except of course that 64bit vs. 32bit file size issue).
John R. Baker, P.E.
Product 'Evangelist'
NX Design
Siemens PLM Software Inc.
Cypress, CA
http://www.siemens.com/plm
Great, thanks for the info.
Now I'm not really sure what OS it was last saved with (we didn't add the Part History record to UG Part files until V10.0) but knowing the customer, I would suspect that it was a DEC VAX system.
So I guess we'd put our support for accessing legacy parts up against anyone in the business (and I'm told that our internal development tests reach back even further).
John R. Baker, P.E.
NX Design
Cypress, CA
Another file that I did have was built on HP Risc using UGII V8, and that had come by way of a troublesome IGES file so it contained older style parametric surfaces and splines with about 100 knot points and a similar number of poles. That one did manage to defy being opened in UG V10 and NX-2. This is an extremely rare circumstance that we didn't bother to fix because we had no further use of the data. The files now live on a DAT tape that I have no reader for and who knows if it will read anyway after all this time.
I thought that somebody would care to know
Cheers
Hudson
Ben Loosli
We weren't aware of CD distribution until around UGII V8 or 9 timeframe.
Cheers
Hudson
ht
John R. Baker, P.E.
NX Design
Cypress, CA
