A2 Place Note Question
Is there a way to constrain the chosen frame around the text?
I use place note to make gridline bubbles, but the number 1 and 2 make different sized bubbles.
Also is there a way to import the detailing tools from v8 to XM?
RE: A2 Place Note Question
and also
in dimension settings under dimstyle >notes
>frame scale .....make sure scale frame is unticked ie off.. depends on text size you might have to set atext scale size for the frame and turn it back on..
circle buble 1 and 2 works perfect for me with scale off... is you text justification cc?
