Lifting Lug Material Allowable stress
I am curious to know why allowable stress for lifting lugs are matched with that of shell or head ? Aren't we required to use the allowable stress @ normal atmospheric temperature i.e 70F or MDMT as vessel rarely experiences design temperature while being lifted ? Thanks
RE: Lifting Lug Material Allowable stress
Joe Tank
"Although this forum is monitored by Codeware it is not intended as a venue for technical support and should not be used as the primary means of technical support."
Tom Barsh
Codeware Technical Support
www.codeware.com
