sheetmetal parts as option on import ?
I'm on version 15 so bear with me on that part..
When opening an .xt file as an assembly is it possible to create the parts as sheetmeetal parts ? all parts default to .par files. I need sheetmetal parts as that's what they are and I need to flatten them ?
Currently I'll have a customer send the assembly xt as well as all individual files as xt's..
thanks in  advance.. Craig
RE: sheetmetal parts as option on import ?
just realized this was in nx  I'm using Solid edge...
It is possible to create a flat pattern from a parasolid (.xt file). You will not need to recreate or change it to a sheet metal part. The flat pattern will come out as curves.
V15 was quite a while ago so I don't remember the exact procedure how to create that flat pattern, but check under the Tools (pull down) > flat pattern.
You will need to make sure your bend, and other, factors are set correctly set. I think you set them at Preferences (pull-down) > sheet metal
Maybe check your HELP documentation, or if you have CAST, for a better step by step procedure.
I am not really sure what a .par file is.
I'd move the thread to the solid edge If I could..Lol
.par =solid parts cant flatten..
.psm sheet metal can flatten..
need quicker way to automatically create .psm files on import..
You can red flag your post if you wish and the forum admins will move or delete it.
