Pin Design
Pin Design
Pin Design
I found most of my answers on here, but one remains.  When talking about shear pins .577 of the Ultimate Stress is used for the failure point.  I'm specing a pin for a hydraulic cylinder, but I don't want it to fail or yield.  Does that mean I should use .577 of the yield strength?
Thank you in advance.
RE: Pin Design
For steel, the shear yield stress is about .58 of the normal yield stress.  However if there is fatigue involved there may be other things to look at.
RE: Pin Design
Thanks for the responses and I did see one of the posts already.  Looking back over it let me correct my earlier statement to .577 of Yield strength.
However I guess what I'm asking, is there a Yield Shear Strength or do pins not yield in shear?  The cylinder clevis is only supported on one side and I don't want it to get bent under load.
Thanks again hopefully this helps clerify my question
RE: Pin Design
Yes, there is a shear yield strength, and it is theoretically 0.577*TYS where TYS is the tensile yield strength.  If you don't want the pin to bend, definitely keep the shear stresses below ~ 1/2 of the tensile yield strength.  Keep in mind that shear applications can still have bending present, which complicates things.
RE: Pin Design
Thanks TVP I just wanted to make sure that is the correct way to deal with the shear yield. I have calculated the Shear Force and the Bending Moment.
