Tensile and Compression Static Load Test
Is there any reason why static compression and tensile load tests cannot be performed on the same pile? The subcontractor wants to use dead weight for compression test and reaction piles for tensile test.
RE: Tensile and Compression Static Load Test
Another problem that often occures is can you get enough tension load in the reaction pile?
