New Workstation Advice Wanted
I have an almost 5 year old Dell 350 workstation that I have been lucky to have used wihout much trouble all this time.
Quick specs are a P4 2.4Ghz, 1.5G RAM, Quadro4 900XGL grahics, dual flat monitors.
I'd like to spend about or under $2k for a new system (minus monitors). I don't need the ultimate system (I work with alot of automation equipment type mechanical assemblies) but I do want something pretty good - time is money in this business! Currently I am seeing a bit of trouble (caused by not enough memory I believe) running SW 2008 sp5 (I just upgraded - and will probably upgrade to 09 in spring).
Does anyone want to take a stab at a suggestion? I prefer to buy a Dell or HP or pre-packaged system - but I might take the plunge and build my own system from components if that seems worth it.
Thanks in advance!
Thanks in advance!
RE: New Workstation Advice Wanted
You can configure a nice system for $2K
Also, see reviews for hardware at Cadalyst.com.
Jeff Mowry
www.industrialdesignhaus.com
A people who value security over freedom will soon find they have neither.
Is a dual core (or quad core) any advantage (do they even make single core anymore) for non-photoshop SW use?
How about 64 bit operating systems vs 32 bit?
-handleman, CSWP (The new, easy test)
ht
I know searching this forum is a pain, but there are loads of posts on this forum, as well as others, as well as great information on workstation components in the Cadalyst.com reviews. Try using Stefan's Google search for Eng-tips.com--works great:
http://ww
http://www.eng-tips.com/faqs.cfm?fid=1336
Jeff Mowry
Buy a built up system, but not necessarily Dell or HP (like maybe XiComputer).
Stick with XP32 OS, Core Duo E8500 processor, and 4G DDR2 Ram(but get a motherboard able to handle at least 8G for future possible switch to Vista64 if more memory becomes needed in years to come).
Not sure about using the 3G switch in XP.
Either a Quadro FX 570 or FX 1700. Wondering if the 57o might be better becuase at 256MB vs 512MB it will use less of the system memory (leaving more available for application).
I would probably just up the memory in my current Dell 350, but the motherboard is maxed out at 1.5G.
This system will cost about $2k (if I include a monitor and XP OS). Should keep me going pretty well for another few years.
Any comments?
I've got a Core 2 Duo E8400 chip and it does very well--particularly for the cost of less than $200 (when this line was new).
Now is certainly a good time to build a system--many of the items are quite inexpensive. Xi does great work and has excellent service.
Jeff Mowry
The new i7 920 2.66GHz processor, 3Gb DDR3 1600MHz RAM, matching motherboard, Quadro FX1700 graphics. Running with XP32. I'll let you know how it performs when I get it next week.
Good luck with assembly. I'd be interested in knowing how well the FX-1700 does for you.
Jeff Mowry
