D-Load calculation
D-Load calculation
D-Load calculation
I am working on D-Load calculations, using the older Marston formula and not the newer methodology.  Standard says to use a "Dead Load Factor of 1.9", however I can't find any reference to this factor in any of the equations.  It seems very conservative to multiply earth loads by 1.9, but this seems to be the requirement.  I wonder if maybe it is a "bedding factor" which could be assumed to be 1.9.  Any thoughts?
RE: D-Load calculation
Is live load traffic/surcharge considered separately?
yes and the other loads are fill or embankment loads (sometimes may be referred to as dead loads)  no "dead load factor" shows up in the literature I have reviewed. For instance, City of Los Angeles Design Manual does not show a dead load factor - see link below.
http://eng.lacity.org/techdocs/str-man/h-300.pdf
